Salta al contenuto principale
DeWalt DW920 Lock Switch Replacement
Cosa ti serve
  1. DeWalt DW920 Lock Switch Replacement, Disassembly: passo 1, immagine 1 di 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Lock Switch Replacement: passo 2, immagine 1 di 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Lock Switch Replacement: passo 3, immagine 1 di 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Lock Switch Replacement, Lock Switch: passo 4, immagine 1 di 1
    • Locate the switch on the top of the drill right before the bending joint.
  5. DeWalt DW920 Lock Switch Replacement: passo 5, immagine 1 di 2 DeWalt DW920 Lock Switch Replacement: passo 5, immagine 2 di 2
    • Firmly grasp the switch with two fingers and lift it straight up. The spring should remain attached to the switch during this process.
    • It should lift right out. If it is caught on anything do not force it out.
Conclusione
Stephen Rada
Membro da: 03/11/16
433 Reputazione
4 Guide realizzate
Un commento
This guide was descriptive and easy to follow. Good job!
DankMemerino - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 286
