Salta al contenuto principale
DeWalt DW660 Power Cord Replacement
Cosa ti serve
  1. DeWalt DW660 Power Cord  Replacement, Power Cord: passo 1, immagine 1 di 2 DeWalt DW660 Power Cord  Replacement, Power Cord: passo 1, immagine 2 di 2
    • Using a T20 Torx Screwdriver, unscrew the four 19mm screws from the back casing.
    • After unscrewing, remove the back casing from the device.
  2. DeWalt DW660 Power Cord  Replacement: passo 2, immagine 1 di 1
    • Disconnect the wires from the switch terminals.
  3. DeWalt DW660 Power Cord  Replacement: passo 3, immagine 1 di 1
    • Remove the ground wire from the motor by pulling it gently.
  4. DeWalt DW660 Power Cord  Replacement: passo 4, immagine 1 di 1
    • Using the T20 Torx screwdriver, unscrew two screws from the bracket that holds the power cord in the casting.
Conclusione
AL25
Membro da: 03/09/16
229 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 361
