Salta al contenuto principale
DeWalt DW660 Motor Brushes Replacement
Cosa ti serve
  1. DeWalt DW660 Motor Brushes Replacement, Motor Brushes: passo 1, immagine 1 di 2 DeWalt DW660 Motor Brushes Replacement, Motor Brushes: passo 1, immagine 2 di 2
    • Remove the four 19mm T20 Torx screws at the rear of the device.
  2. DeWalt DW660 Motor Brushes Replacement: passo 2, immagine 1 di 3 DeWalt DW660 Motor Brushes Replacement: passo 2, immagine 2 di 3 DeWalt DW660 Motor Brushes Replacement: passo 2, immagine 3 di 3
    • Remove the other part of the back casing.
    • Unplug the black and white power wires from the motor.
  3. DeWalt DW660 Motor Brushes Replacement: passo 3, immagine 1 di 2 DeWalt DW660 Motor Brushes Replacement: passo 3, immagine 2 di 2
    • Pinch the blue brush wire between two fingers.
    • Pull on the wire, removing them from the motor.
  4. DeWalt DW660 Motor Brushes Replacement: passo 4, immagine 1 di 2 DeWalt DW660 Motor Brushes Replacement: passo 4, immagine 2 di 2
    • Using the metal spudger, lift up the coil spring that holds the carbon brushes in place.
    • While the spring is lifted up, remove the carbon brush by simply sliding it out of the slot.
  5. DeWalt DW660 Motor Brushes Replacement: passo 5, immagine 1 di 2 DeWalt DW660 Motor Brushes Replacement: passo 5, immagine 2 di 2
    • Repeat steps 3 and 4 to remove the other carbon brush.
    • When installing the new carbon brushes, make sure each brushes' lead wire is plugged into opposite ends of the motor.
    • Refer to the photos for visual assistance.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,429
