Salta al contenuto principale
DeWalt DW235G Drill Power Cord Replacement
Cosa ti serve
  1. DeWalt DW235G Drill Power Cord Replacement, Handle Cover: passo 1, immagine 1 di 1
    • Remove the three screws with a Tr20 hex bit screwdriver.
    • Remove the back cover.
  2. DeWalt DW235G Drill Power Cord Replacement, Power Cord: passo 2, immagine 1 di 1
    • Unscrew the Tr20 Hex Screw connecting the green wire to the power cord.
    • Ensure the power drill is unplugged before disconnecting wires.
  3. DeWalt DW235G Drill Power Cord Replacement: passo 3, immagine 1 di 2 DeWalt DW235G Drill Power Cord Replacement: passo 3, immagine 2 di 2
    • Disconnect all the wires connected from the trigger box and power cord to the drill motor by pulling on the connectors.
    • There will be 5 wires to disconnect: 2 black, a white, a red, and a blue wire. Remember the locations of where they were connected so you can reconnect them later.
  4. DeWalt DW235G Drill Power Cord Replacement: passo 4, immagine 1 di 1
    • Remove the trigger box and power cord from the main chassis.
  5. DeWalt DW235G Drill Power Cord Replacement: passo 5, immagine 1 di 1
    • Disconnect the wires connecting the power cord to the trigger box by pressing on the clips with a spudger tool.
    • There will be 3 wires to disconnect: A black, white, and green wire. Remember what color attaches to each connector on the trigger box.
    • For reassembly, insert the wires back into the trigger box until a click is heard.
Conclusione
The power cord will now be disconnect and you can replace it with a new one.
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 120
Tutti i Tempi: 410
