Salta al contenuto principale
DeWalt DW235G Drill Chuck Part Replacement
Cosa ti serve
  1. DeWalt DW235G Drill Chuck Part Replacement, Chuck Component: passo 1, immagine 1 di 1
    • Identify the Hex nut within the inside of the chuck of the drill.
    • Insert the 4mm Allen key into the chuck to loosen the Hex nut.
    • The Hex nut is reversed threaded. To loosen the nut, simply twist the 4mm Allen key in the opposite direction.
  2. DeWalt DW235G Drill Chuck Part Replacement: passo 2, immagine 1 di 1
    • Re-insert the 4mm Allen key into the chuck after the Hex nut has been taken out.
    • Make sure that the 4mm Allen key is firmly in place inside the chuck.
  3. DeWalt DW235G Drill Chuck Part Replacement: passo 3, immagine 1 di 1
    • Using a hammer or blunt object, strike the 4mm Allen key in order to break loose the chuck from the body of the drill.
    • Make sure the drill is thoroughly secured before striking.
Conclusione
To actually install the chuck replacement part, follow the guide in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 68
Tutti i Tempi: 237
