Salta al contenuto principale
DeWalt DCS380 Motor Armature Replacement
Cosa ti serve
  1. DeWalt DCS380 Motor Armature Replacement, Removing shoe and boot.: passo 1, immagine 1 di 1
    • Remove the battery before disassembly.
    • Remove the shoe by pressing the yellow button on the left side of the hand grip.
  2. DeWalt DCS380 Motor Armature Replacement: passo 2, immagine 1 di 2 DeWalt DCS380 Motor Armature Replacement: passo 2, immagine 2 di 2
    • Remove the two M8x18mm T20 bolts from the front plate.
  3. DeWalt DCS380 Motor Armature Replacement: passo 3, immagine 1 di 1
    • Pull the front of the grip while holding the saw body in place.
  4. DeWalt DCS380 Motor Armature Replacement, DeWalt DCS380 Grip Disassembly: passo 4, immagine 1 di 2 DeWalt DCS380 Motor Armature Replacement, DeWalt DCS380 Grip Disassembly: passo 4, immagine 2 di 2
    • Remove the battery before dissasembly.
    • Remove the M3x16mm T10 screw from the back of the grip. Keep it separate from the rest of the grip screws
    • Remove the six M3.63x19 T15 screws from the grip.
  5. DeWalt DCS380 Motor Armature Replacement: passo 5, immagine 1 di 3 DeWalt DCS380 Motor Armature Replacement: passo 5, immagine 2 di 3 DeWalt DCS380 Motor Armature Replacement: passo 5, immagine 3 di 3
    • Remove the top half of the grip.
    • Turn the saw over and locate the power connectors to the motor.
    • Use needle nose pliers to remove the spade connectors. Take care not to grab the wires on removal, only the end of the spade terminal.
    • Note the polarity for the power connectors and be sure they are not reversed on reassembly.
  6. DeWalt DCS380 Motor Armature Replacement, Motor Armature: passo 6, immagine 1 di 2 DeWalt DCS380 Motor Armature Replacement, Motor Armature: passo 6, immagine 2 di 2
    • Remove three M8x18 T20 bolts from the back of the gearbox.
    • Pull the motor case off of the armature.
  7. DeWalt DCS380 Motor Armature Replacement: passo 7, immagine 1 di 2 DeWalt DCS380 Motor Armature Replacement: passo 7, immagine 2 di 2
    • Remove two M8x12mm T20 bolts from the bearing retainer.
    • Pull the shaft out of the gearbox.
    • Please note, the brushes will need to be disengaged to reassemble the motor. See the end of the Motor Brush replacement section of this guide for details.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 25
Tutti i Tempi: 984
