Salta al contenuto principale
DeWalt DCF885 Selector Switch Replacement
Cosa ti serve
  1. DeWalt DCF885 Selector Switch Replacement, Battery: passo 1, immagine 1 di 1
    • Press the battery release button at the top of the battery.
  2. DeWalt DCF885 Selector Switch Replacement: passo 2, immagine 1 di 1
    • Pull the battery away from the tool.
  3. DeWalt DCF885 Selector Switch Replacement, Motor Assembly: passo 3, immagine 1 di 1
    • Remove the eight 18 mm Torx Security #10 screws.
  4. DeWalt DCF885 Selector Switch Replacement: passo 4, immagine 1 di 1
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. DeWalt DCF885 Selector Switch Replacement: passo 5, immagine 1 di 1
    • Disconnect the connector from the motor assembly.
  6. DeWalt DCF885 Selector Switch Replacement: passo 6, immagine 1 di 1
    • Pull the motor away from the brush assembly.
  7. DeWalt DCF885 Selector Switch Replacement, Brush Assembly: passo 7, immagine 1 di 1
    • Lift the brush assembly out of the drill case.
  8. DeWalt DCF885 Selector Switch Replacement: passo 8, immagine 1 di 1
    • Pull the armature assembly apart from the brush ring assembly.
  9. DeWalt DCF885 Selector Switch Replacement: passo 9, immagine 1 di 1
    • Pry the two circled connectors apart from the brush ring assembly.
  10. DeWalt DCF885 Selector Switch Replacement: passo 10, immagine 1 di 1
    • The brush assembly is now removed from the drill body.
  11. DeWalt DCF885 Selector Switch Replacement, Switch Assembly: passo 11, immagine 1 di 1
    • Pull the switch assembly up and out of the drill case.
  12. DeWalt DCF885 Selector Switch Replacement, Selector Switch: passo 12, immagine 1 di 1
    • Pull the selector switch out from the outer case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 25
Tutti i Tempi: 696
