Salta al contenuto principale
DeWalt D26451 Power Switch Replacement
Cosa ti serve
  1. DeWalt D26451 Power Switch Replacement, Power Cord: passo 1, immagine 1 di 1
    • Please wear safety glasses while completing this guide.
    • Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
  2. DeWalt D26451 Power Switch Replacement: passo 2, immagine 1 di 1
    • Gently pry the cap off using your fingers or spudger tool.
  3. DeWalt D26451 Power Switch Replacement: passo 3, immagine 1 di 1
    • Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment. Once the cord is loose, pull the connectors out
  4. DeWalt D26451 Power Switch Replacement: passo 4, immagine 1 di 1
    • Loosen the white and black wire terminals
  5. DeWalt D26451 Power Switch Replacement: passo 5, immagine 1 di 1
    • Insert new power cord terminals and tighten down
    • Do not over-tighten
  6. DeWalt D26451 Power Switch Replacement, Power Switch: passo 6, immagine 1 di 1
    • Remove screws (3) from the cap using a T20 torx attachment by unscrewing in a leftward motion
  7. DeWalt D26451 Power Switch Replacement: passo 7, immagine 1 di 1
  8. DeWalt D26451 Power Switch Replacement: passo 8, immagine 1 di 1
    • Once the cap is removed, the switch and connectors should be exposed
  9. DeWalt D26451 Power Switch Replacement: passo 9, immagine 1 di 1
    • Remove both connectors from the switch
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,270
