Salta al contenuto principale
DeWalt D26451 Power Cord Replacement
Cosa ti serve
  1. DeWalt D26451 Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
    • Please wear safety glasses while completing this guide.
    • Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
  2. DeWalt D26451 Power Cord Replacement: passo 2, immagine 1 di 1
    • Gently pry the cap off using your fingers or spudger tool.
  3. DeWalt D26451 Power Cord Replacement: passo 3, immagine 1 di 1
    • Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment. Once the cord is loose, pull the connectors out
  4. DeWalt D26451 Power Cord Replacement: passo 4, immagine 1 di 1
    • Loosen the white and black wire terminals
  5. DeWalt D26451 Power Cord Replacement: passo 5, immagine 1 di 1
    • Insert new power cord terminals and tighten down
    • Do not over-tighten
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,287
