Salta al contenuto principale
DeWALT Hammer Drill DW511 Power Cord Replacement
Cosa ti serve
  1. DeWALT Hammer Drill DW511 Power Cord Replacement, Back Cover: passo 1, immagine 1 di 3 DeWALT Hammer Drill DW511 Power Cord Replacement, Back Cover: passo 1, immagine 2 di 3 DeWALT Hammer Drill DW511 Power Cord Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. DeWALT Hammer Drill DW511 Power Cord Replacement: passo 2, immagine 1 di 3 DeWALT Hammer Drill DW511 Power Cord Replacement: passo 2, immagine 2 di 3 DeWALT Hammer Drill DW511 Power Cord Replacement: passo 2, immagine 3 di 3
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. DeWALT Hammer Drill DW511 Power Cord Replacement, Power Cord: passo 3, immagine 1 di 2 DeWALT Hammer Drill DW511 Power Cord Replacement, Power Cord: passo 3, immagine 2 di 2
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. DeWALT Hammer Drill DW511 Power Cord Replacement: passo 4, immagine 1 di 3 DeWALT Hammer Drill DW511 Power Cord Replacement: passo 4, immagine 2 di 3 DeWALT Hammer Drill DW511 Power Cord Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. DeWALT Hammer Drill DW511 Power Cord Replacement: passo 5, immagine 1 di 3 DeWALT Hammer Drill DW511 Power Cord Replacement: passo 5, immagine 2 di 3 DeWALT Hammer Drill DW511 Power Cord Replacement: passo 5, immagine 3 di 3
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. DeWALT Hammer Drill DW511 Power Cord Replacement: passo 6, immagine 1 di 1
    • With both wires free, the power cord is free from the trigger body.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,442
