Salta al contenuto principale
DeWALT Hammer Drill DW511 Lever Assembly Replacement
Cosa ti serve
  1. DeWALT Hammer Drill DW511 Lever Assembly Replacement, Back Cover: passo 1, immagine 1 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Back Cover: passo 1, immagine 2 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 2, immagine 1 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 2, immagine 2 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 2, immagine 3 di 3
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. DeWALT Hammer Drill DW511 Lever Assembly Replacement, Power Cord: passo 3, immagine 1 di 2 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Power Cord: passo 3, immagine 2 di 2
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 4, immagine 1 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 4, immagine 2 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 5, immagine 1 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 5, immagine 2 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 5, immagine 3 di 3
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 6, immagine 1 di 1
    • With both wires free, the power cord is free from the trigger body.
  7. DeWALT Hammer Drill DW511 Lever Assembly Replacement, Brushes: passo 7, immagine 1 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Brushes: passo 7, immagine 2 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Brushes: passo 7, immagine 3 di 3
    • Use an opening tool to lift up the spring holding down the brush.
    • Remove the brush from its holding.
  8. DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 8, immagine 1 di 2 DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 8, immagine 2 di 2
    Compra
    • With a pair of blunt nose tweezers, grab the red wire.
  9. DeWALT Hammer Drill DW511 Lever Assembly Replacement, Lever Assembly: passo 9, immagine 1 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Lever Assembly: passo 9, immagine 2 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Lever Assembly: passo 9, immagine 3 di 3
    • Remove two 45 mm T20 Torx screws.
    • Remove one 30 mm T20 Torx screw.
  10. DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 10, immagine 1 di 1
    • Pull off the top case and set it aside.
  11. DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 11, immagine 1 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 11, immagine 2 di 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 11, immagine 3 di 3
    • Grab the gear case cover and gently pull it out just enough to where it exposes the lever assembly.
    • It is important that the brushes are removed before you do this step or you may damage your brushes.
    • The lever assembly can now be lifted out.
  12. DeWALT Hammer Drill DW511 Lever Assembly Replacement: passo 12, immagine 1 di 1
    • With the old lever assembly removed you can now replace it with a new one.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 375
