Introduzione
Welcome to the DeWALT Hammer Drill DW511 brush replacement guide. The brushes are an important part of the drill that keep the field clean of debris. You would want to replace the brush because of wear or chipping.
Caution should be taken when working with on the device. It needs to be unplugged before working on any part of the drill.
Cosa ti serve
Firmly grab the body of the trigger.
Slowly pull the trigger until the entire body is out and only attached by wires.
Use an opening tool to lift up the spring holding down the brush.
Remove the brush from its holding.
