Introduzione
For most repairs, the device must be opened. These instructions show how to remove the side panels.
Cosa ti serve
Remove all coffee beans. Remove all attachments such as drip tray, milk frother and water tank. Open the service door and remove the brew group.
Unscrew the two Phillips screws
The Phillips screw under the water tank can remain.
The right side panel is removed in the same way, but the service hatch is a bit obstructive. Open it first and push the side panel back a few millimeters. This is often difficult and you will need a plastic lever tool.
Close the flap again and push the sides further back. It is a bit tricky and you have to work carefully. Lift out the side panel.
Work through the steps in reverse order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
100%
shingle ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
