Salta al contenuto principale
DeLonghi ESAM 3000.B Magnifica disassembling
Cosa ti serve
  1. DeLonghi ESAM 3000.B Magnifica disassembling, Preparations: passo 1, immagine 1 di 1
    • Pull the plug!
    • Remove the drip tray, the water tank and the pulp container.
  2. DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew the rear panel: passo 2, immagine 1 di 2 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew the rear panel: passo 2, immagine 2 di 2
    • The rear panel and side panels are attached with six phillips screws #2. Screw them out.
  3. DeLonghi ESAM 3000.B Magnifica disassembling, Remove right side panel: passo 3, immagine 1 di 2 DeLonghi ESAM 3000.B Magnifica disassembling, Remove right side panel: passo 3, immagine 2 di 2
    • Slide the right side panel about 2 cm to the back.
    • Then solve it.
  4. DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: passo 4, immagine 1 di 3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: passo 4, immagine 2 di 3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: passo 4, immagine 3 di 3
    • The left side is a bit stuck. Place a plastic opening tool in the gap between the front and left side panel above the opening for the water tank. Lift the gap slightly larger.
    • Then place the tool in the gap between the front and left side panel under the opening for the water tank. Increase the gap and push the side part about 2 cm to the rear.
    • Lift out the left side piece.
  5. DeLonghi ESAM 3000.B Magnifica disassembling, Remove rear panel: passo 5, immagine 1 di 1
    • Take out the rear panel.
  6. DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: passo 6, immagine 1 di 3 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: passo 6, immagine 2 di 3 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: passo 6, immagine 3 di 3
    • The front panel is secured with four PH2 Phillips screws, two left and one right each. Turn it out.
    • Use a plastic opening tool to lever off the steam tap.
    • Carefully pull the front panel about 1 cm forward so that there is a gap between the top cover and the front panel,
    • Do not pull the front panel too far, it is still attached with different hoses and cables.
  7. DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: passo 7, immagine 1 di 3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: passo 7, immagine 2 di 3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: passo 7, immagine 3 di 3
    • Two Phillips screws PH2 hold the lid at the back. Turn it out.
    • Lift the lid upwards.
Conclusione
Follow the steps in reverse order to reassemble your device.
Altre 15 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
VauWeh
Membro da: 10/19/15
297.278 Reputazione
303 Guide realizzate
4Commenti sulla guida
Bonjour et merci pour le partage;
Comment démonter le panneau de commandes à l’avant svp, il semblerait que le bouton rond qui permet de régler la quantité d’eau par tasse ne répond plus normalement. En effet en choisissant une double tasse et en ayant tourner ce bouton au maximum pour la quantité de café par tasse, j’obtiens un tiers de bol…ce bouton se serait il décalé??? ou est ce plutôt un autre problème? avez vous une idée svp? Merci d’avance pour vos réponses.
Laurence MUNSCH - Replica
Le régulateur réagit-il ? Si vous le retournez, est-ce qu'il produit aussi moins de café ? Il existe de nombreuses possibilités : le débitmètre, la pompe, le piston supérieur…
VauWeh -
Bonjour j ai le bouton service toujours allumé. Pas détartrage mais je pense un problème électrique.
Qq peux m aider merci
yacoub bouanene - Replica
Utilisez le mode test pour trouver une solution. C'est en allemand, traduisez avec Google Translate.
VauWeh -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 112
Ultimi 30 Giorni: 412
Tutti i Tempi: 26,249
