Salta al contenuto principale
Datawind Ubislate 7ci Speaker Replacement
Cosa ti serve
  1. Datawind Ubislate 7ci Speaker Replacement, Finding a workspace: passo 1, immagine 1 di 1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: passo 2, immagine 1 di 2 Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: passo 2, immagine 2 di 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated, your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves)
  3. Datawind Ubislate 7ci Speaker Replacement, Removing the speaker: passo 3, immagine 1 di 1
    • Use your prying tool to pop the speaker out from its housing.
  4. Datawind Ubislate 7ci Speaker Replacement, Detach from contact points: passo 4, immagine 1 di 1
    • Use a soldering iron to remove the speaker from its contact points.
  5. Datawind Ubislate 7ci Speaker Replacement, Attaching replacement to contact points: passo 5, immagine 1 di 1
    • Solder your new speaker to the same contact points as before.
  6. Datawind Ubislate 7ci Speaker Replacement, Housing the replacement speaker: passo 6, immagine 1 di 1
    • Apply a small amount of adhesive to the new speaker, and place it into the housing on the back panel.
  7. Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: passo 7, immagine 1 di 2 Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: passo 7, immagine 2 di 2
    • Put the two halves back together.
    • Push down on the edges until you hear them click into place.
Conclusione
Mekides
Membro da: 10/20/14
40 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 299
