Salta al contenuto principale
Datawind Ubislate 7ci Rear Facing Camera Replacement
Cosa ti serve
  1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: passo 1, immagine 1 di 1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: passo 2, immagine 1 di 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: passo 2, immagine 2 di 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.)
  3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: passo 3, immagine 1 di 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: passo 3, immagine 2 di 2
    • Remove the black tape that is circled.
    • The camera is circled in this picture.
  4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: passo 4, immagine 1 di 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: passo 4, immagine 2 di 2
    • Carefully remove the camera from its housing.
  5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: passo 5, immagine 1 di 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: passo 5, immagine 2 di 2
    • Slide the new camera into its housing carefully.
    • it should look like the second picture when you are finished
  6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: passo 6, immagine 1 di 1
    • Press the back cover of the tablet on firmly until it clicks
Conclusione
Altre 2 persone hanno completato questa guida.
Mekides
Membro da: 10/20/14
40 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 305
