Salta al contenuto principale
Datawind Ubislate 7ci Battery Replacement
Cosa ti serve
  1. Datawind Ubislate 7ci Battery Replacement, Battery: passo 1, immagine 1 di 2 Datawind Ubislate 7ci Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • Be careful of the device's small wiring when separating the two halves.
  2. Datawind Ubislate 7ci Battery Replacement: passo 2, immagine 1 di 3 Datawind Ubislate 7ci Battery Replacement: passo 2, immagine 2 di 3 Datawind Ubislate 7ci Battery Replacement: passo 2, immagine 3 di 3
    • Remove the black tape.
    • Be careful not to remove the tablet camera.
  3. Datawind Ubislate 7ci Battery Replacement: passo 3, immagine 1 di 3 Datawind Ubislate 7ci Battery Replacement: passo 3, immagine 2 di 3 Datawind Ubislate 7ci Battery Replacement: passo 3, immagine 3 di 3
    • Use a soldering iron to remove the battery from both its attachment points.
    • Pry off the battery using an opening tool.
  4. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: passo 4, immagine 1 di 2 Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: passo 4, immagine 2 di 2
    • Insert your replacement battery in the same spot as the old battery.
    • Tape battery into place.
  5. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: passo 5, immagine 1 di 2 Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: passo 5, immagine 2 di 2
    • Solder the new battery to the connection points.
    • Press the back cover on firmly until it clicks.
Conclusione
Altre 6 persone hanno completato questa guida.
Mekides
Membro da: 10/20/14
40 Reputazione
3 Guide realizzate
2 Commenti
On my 7Ci the battery is SFH-HLKJ-204.
Datawind doesn't sale those pieces.
Where can I find one?
What type is it, voltage and so?
THX!
ylco - Replica
3.7V, 2200mAh lithium ion. Yiu can get a bigger or smaller one depending on shat you want.
Jessica Parnelli Fawkes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 9,075
