Salta al contenuto principale
Dashcam DOD LS300W Battery Replacement
Cosa ti serve
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: passo 1, immagine 1 di 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: passo 1, immagine 2 di 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: passo 1, immagine 3 di 3
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: passo 2, immagine 1 di 2 Dashcam DOD LS300W Battery Replacement: passo 2, immagine 2 di 2
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: passo 3, immagine 1 di 3 Dashcam DOD LS300W Battery Replacement: passo 3, immagine 2 di 3 Dashcam DOD LS300W Battery Replacement: passo 3, immagine 3 di 3
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: passo 4, immagine 1 di 1
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
Conclusione
Once again, thank you for checking out this guide and I hope it helped!
Altre 2 persone hanno completato questa guida.
Pierre
Membro da: 04/02/13
542 Reputazione
3 Guide realizzate
2 Commenti
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - Replica
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 27
Tutti i Tempi: 6,325
