Salta al contenuto principale
DYMO LabelPOINT 100 Cutting Blade Replacement
Cosa ti serve
  1. DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: passo 1, immagine 1 di 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: passo 1, immagine 2 di 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: passo 1, immagine 3 di 3
    • Slide the panel release button.
    • Lift the panel.
  2. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Label Tape Cassette: passo 2, immagine 1 di 2 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Label Tape Cassette: passo 2, immagine 2 di 2
    • Firmly press the cartridge release button with your finger.
    • You may need to hold the cassette and/or entire device still while pressing the button.
    • Lift the label tape cassette out of the device.
  3. DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: passo 3, immagine 1 di 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: passo 3, immagine 2 di 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: passo 3, immagine 3 di 3
    • Use Phillips #00 Screwdriver to disengage cutter from device
    • Remove cutter
  4. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: passo 4, immagine 1 di 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: passo 4, immagine 2 di 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: passo 4, immagine 3 di 3
    • Use Phillips #00 screw to unscrew blade from blade cutter
    • Carefully remove blade. The blade is sharp and can be dangerous if not handled properly.
    • Replace blade
Conclusione
USF Tampa, Team 5-2, Mcgee Fall 2014 Membro di USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
4 Membri
6 Guide realizzate
Un commento
dangerous? Really :) haha anyway nice review.
speedy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,417
