Salta al contenuto principale
DYMO LabelPOINT 100 Battery Replacement
Cosa ti serve
  1. DYMO LabelPOINT 100 Battery Replacement, Removing Battery Cover: passo 1, immagine 1 di 2 DYMO LabelPOINT 100 Battery Replacement, Removing Battery Cover: passo 1, immagine 2 di 2
    • Slide the battery cover release button.
    • Remove battery cover.
  2. DYMO LabelPOINT 100 Battery Replacement, Removing Batteries: passo 2, immagine 1 di 3 DYMO LabelPOINT 100 Battery Replacement, Removing Batteries: passo 2, immagine 2 di 3 DYMO LabelPOINT 100 Battery Replacement, Removing Batteries: passo 2, immagine 3 di 3
    • Remove all six Triple A batteries.
    • If applicable, pull on the black ribbon to release all six Triple A batteries at the same time.
    • Be careful not to damage any of the spring terminals when removing the batteries.
Conclusione
To reassemble your device, follow these instructions in reverse order. If applicable, make sure to set the black ribbon first for future disassembly.
Mike Dam
Membro da: 09/25/14
201 Reputazione
2 Guide realizzate
USF Tampa, Team 5-2, Mcgee Fall 2014 Membro di USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,258
