Salta al contenuto principale
DYMO LabelManager 160 Keyboard Replacement
Cosa ti serve
  1. DYMO LabelManager 160 Keyboard Replacement, Batteries: passo 1, immagine 1 di 1
    • Place the device face-down to access the battery compartment.
  2. DYMO LabelManager 160 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. DYMO LabelManager 160 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • To open the cartridge compartment, simply lift on the front of the device.
  4. DYMO LabelManager 160 Keyboard Replacement: passo 4, immagine 1 di 2 DYMO LabelManager 160 Keyboard Replacement: passo 4, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. DYMO LabelManager 160 Keyboard Replacement: passo 5, immagine 1 di 1
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. DYMO LabelManager 160 Keyboard Replacement: passo 6, immagine 1 di 3 DYMO LabelManager 160 Keyboard Replacement: passo 6, immagine 2 di 3 DYMO LabelManager 160 Keyboard Replacement: passo 6, immagine 3 di 3
    • Gently remove the rubber keyboard from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
3 Commenti
Group 9: Over all looks great. Screwdriver at top of page should be under tools not parts.
In Step 4 the screws in the second picture 2x 1.2mm should be circled in orange and should be a separate bullet with appropriate coloring.
Possibly add a picture using the spudger, so the user knows exactly where they need to pry.
Fantastic lighting and clear pictures!
Zachary Parker - Replica
Where do I get a replacement key boars
willow williams - Replica
Where did you obtain the parts from as I am having difficulty
Tommy Taylor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,032
