Salta al contenuto principale
DROCON Ninja Casing Replacement
Cosa ti serve
  1. DROCON Ninja Casing Replacement, Battery: passo 1, immagine 1 di 3 DROCON Ninja Casing Replacement, Battery: passo 1, immagine 2 di 3 DROCON Ninja Casing Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Casing Replacement, Casing: passo 2, immagine 1 di 3 DROCON Ninja Casing Replacement, Casing: passo 2, immagine 2 di 3 DROCON Ninja Casing Replacement, Casing: passo 2, immagine 3 di 3
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Casing Replacement: passo 3, immagine 1 di 2 DROCON Ninja Casing Replacement: passo 3, immagine 2 di 2
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Casing Replacement: passo 4, immagine 1 di 3 DROCON Ninja Casing Replacement: passo 4, immagine 2 di 3 DROCON Ninja Casing Replacement: passo 4, immagine 3 di 3
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 251
