Introduzione
This guide will be helpful for removing the protective speaker grill on your DOSS SoundBox. Removing this protective speaker grill will help you get to the speakers if they or the grill is damaged and needs repaired. The process should take around 5 minutes to complete, and doesn't need any special skills. Be aware of the possibility of scratching the soundbox when removing grill.
Cosa ti serve
Use a small plastic opening tool to gently lift the side of the grille.
Gently slide the tool to the front of the speaker.
Repeat the process on the bottom of the grille.
Gently pull the grille off of the speaker enclosure.
