Salta al contenuto principale
DOSS SoundBox Base-plate Replacement
Cosa ti serve
  1. DOSS SoundBox Base-plate Replacement, Base-plate: passo 1, immagine 1 di 3 DOSS SoundBox Base-plate Replacement, Base-plate: passo 1, immagine 2 di 3 DOSS SoundBox Base-plate Replacement, Base-plate: passo 1, immagine 3 di 3
    • Locate the four 3/32" screws on the bottom of your device.
    • Using a JIS #00 screwdriver, remove the four 3/32" screws.
    • After removing the screws, lift the cover off of the device.
  2. DOSS SoundBox Base-plate Replacement: passo 2, immagine 1 di 1
    • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
    • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
    • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
  3. DOSS SoundBox Base-plate Replacement: passo 3, immagine 1 di 1
    • Lift the base-plate off of the enclosure.
Conclusione
Altre 3 persone hanno completato questa guida.
1Commento della guida
Speaker had an unusual sound. Followed guide, really easy to work on. Diagnosis broken speaker membrane.
Albi No - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 35
Tutti i Tempi: 2,343
