Salta al contenuto principale
DJI Spark Cooling Fan Replacement
Cosa ti serve
  1. DJI Spark Cooling Fan Replacement, Propellers: passo 1, immagine 1 di 1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Cooling Fan Replacement: passo 2, immagine 1 di 2 DJI Spark Cooling Fan Replacement: passo 2, immagine 2 di 2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Cooling Fan Replacement, Battery: passo 3, immagine 1 di 3 DJI Spark Cooling Fan Replacement, Battery: passo 3, immagine 2 di 3 DJI Spark Cooling Fan Replacement, Battery: passo 3, immagine 3 di 3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Cooling Fan Replacement, Lid: passo 4, immagine 1 di 3 DJI Spark Cooling Fan Replacement, Lid: passo 4, immagine 2 di 3 DJI Spark Cooling Fan Replacement, Lid: passo 4, immagine 3 di 3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Cooling Fan Replacement: passo 5, immagine 1 di 3 DJI Spark Cooling Fan Replacement: passo 5, immagine 2 di 3 DJI Spark Cooling Fan Replacement: passo 5, immagine 3 di 3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Cooling Fan Replacement, Cooling Fan: passo 6, immagine 1 di 3 DJI Spark Cooling Fan Replacement, Cooling Fan: passo 6, immagine 2 di 3 DJI Spark Cooling Fan Replacement, Cooling Fan: passo 6, immagine 3 di 3
    • Remove the fan.
    • It is attached to the motherboard with several pieces of adhesive.
  7. DJI Spark Cooling Fan Replacement: passo 7, immagine 1 di 2 DJI Spark Cooling Fan Replacement: passo 7, immagine 2 di 2
    • Trace the fan wires to the side of the panel.
    • Unplug the wire from its connector.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 39
Tutti i Tempi: 1,400
