Salta al contenuto principale
DJI Spark Controller Mobile Device Grip Replacement
Cosa ti serve
  1. DJI Spark Controller Mobile Device Grip Replacement, Mobile Device Grip: passo 1, immagine 1 di 1
    • Unfold the arm.
    • Extend the controller’s arm as you would before normally flying the drone.
    • To avoid obstruction, make sure the screwheads of the grip are parallel to the body of the controller.
  2. DJI Spark Controller Mobile Device Grip Replacement: passo 2, immagine 1 di 3 DJI Spark Controller Mobile Device Grip Replacement: passo 2, immagine 2 di 3 DJI Spark Controller Mobile Device Grip Replacement: passo 2, immagine 3 di 3
    • Remove the grip.
    • Remove two screws using a T6 torx screwdriver.
    • Use this same procedure for both arms.
  3. DJI Spark Controller Mobile Device Grip Replacement: passo 3, immagine 1 di 2 DJI Spark Controller Mobile Device Grip Replacement: passo 3, immagine 2 di 2
    • Once both screws are removed, the grip parts come off easily.
    • Be carful when doing this step because the two parts of the grip might fall once the two screws are removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 646
