Salta al contenuto principale
DJI Phantom 4 Advanced Ultrasonic Sensor Replacement
Cosa ti serve
  1. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement, Propeller: passo 1, immagine 1 di 2 DJI Phantom 4 Advanced Ultrasonic Sensor Replacement, Propeller: passo 1, immagine 2 di 2
    • Use your finger tips to pinch the damaged propeller.
    • Twist the propeller counterclockwise and pull up to remove.
  2. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement, Shell: passo 2, immagine 1 di 2 DJI Phantom 4 Advanced Ultrasonic Sensor Replacement, Shell: passo 2, immagine 2 di 2
    • Remove the eight 7 mm hex screws by turning counterclockwise with a 2 mm hex bit.
  3. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 3, immagine 1 di 1
    • Pry the LED motor covers off with a metal spudger.
    • The prying location is marked by an indent that points outward from the arm.
  4. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 4, immagine 1 di 1
    • Pry the paper covering off the four corners with a metal spudger.
  5. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 5, immagine 1 di 1
    • Remove the twelve 8.7 mm hex screws with a 2 mm hex bit from the motor bases.
  6. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 6, immagine 1 di 2 DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 6, immagine 2 di 2
    • Flip the drone on its back
    • Remove the eight 4.5 mm hex screws by turning them counterclockwise with a 1.5 mm hex bit.
    • Separate the mesh from the drone by pulling up gently and rocking left to right.
    • The cable connects from the camera to the drone. Pulling up could rip the connection. Tilt the mesh 90 degrees towards the cable.
  7. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 7, immagine 1 di 1
    • Remove two 1.2mm screws using the JIS #000 bit from the camera cable retaining bracket.
  8. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 8, immagine 1 di 1
    • Lift the camera connector at one end with your hand and remove the mesh.
  9. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 9, immagine 1 di 3 DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 9, immagine 2 di 3 DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 9, immagine 3 di 3
    • Remove the two 1.2 mm screws using a JIS #000 bit from the antenna retaining bracket.
    • Pull the four U.FL antennae up.
    • The U.FL antenna connectors are fragile.
    • Remove the two 4 mm screws using a JIS #000 bit.
  10. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 10, immagine 1 di 2 DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 10, immagine 2 di 2
    • Pry apart the clamshell at the motor end.
    • Separate the clamshell.
    • Two wires connect from the lower frame to the upper frame at the front of the drone. Pulling the clamshell apart hard may damage the connectors and wires.
  11. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 11, immagine 1 di 1
    • Press the connector tabs with a spudger and pull on the wire simultaneously.
    • Remove the shell from the rest of the drone.
  12. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement, Ultrasonic Sensor: passo 12, immagine 1 di 2 DJI Phantom 4 Advanced Ultrasonic Sensor Replacement, Ultrasonic Sensor: passo 12, immagine 2 di 2
    • Remove the three 2.8 mm screws with a JIS #000 screwdriver.
    • The screw on the back of the ultrasonic sensor is covered by foam.
  13. DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 13, immagine 1 di 2 DJI Phantom 4 Advanced Ultrasonic Sensor Replacement: passo 13, immagine 2 di 2
    • Pry the ribbon cable off the ultrasonic sensor using a plastic opening tool.
Conclusione
David Hudson
Membro da: 10/08/18
301 Reputazione
2 Guide realizzate
Cal Poly, Team S15-G6, White Fall 2018 Membro di Cal Poly, Team S15-G6, White Fall 2018
CPSU-WHITE-F18S15G6
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,204
