Salta al contenuto principale
DJI Phantom 4 Advanced Remote Controller Power Button Replacement
Cosa ti serve
  1. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 2, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 2, immagine 2 di 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 3, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 4, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 4, immagine 2 di 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 5, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 5, immagine 2 di 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: passo 6, immagine 1 di 3 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: passo 6, immagine 2 di 3 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: passo 6, immagine 3 di 3
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 7, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 7, immagine 2 di 2
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 8, immagine 1 di 1
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
  9. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: passo 9, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: passo 9, immagine 2 di 2
    • Carefully remove the plastic. This will help you gain access to the power button panel.
  10. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 10, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 10, immagine 2 di 2
    • With a Phillips #00 screwdriver, remove the two screws on the power button panel.
  11. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: passo 11, immagine 1 di 1
    • Gently pull the power button out from the panel. Replace it with a new one.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,031
