Salta al contenuto principale
Introduzione
This guide will show you how to remove and replace the motherboard of the DJI Phantom 4 Advanced Remote Controller.
Before you begin:
  • Please make sure to completely power off the the controller prior to any replacements.
  • Please read the guide before any replacements in order to familiarize yourself with the process.
  1. Remove the four screws with a Torx T8 screwdriver to access the back con board.
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. Remove three screws using a Phillips #00 screwdriver. Remove three screws using a Phillips #00 screwdriver.
    • Remove three screws using a Phillips #00 screwdriver.
  3. With tweezers, gently remove the large con board tab. Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. Peel off the rubber grips to access the screw holes. Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. Pull apart the back plastic panel. Recommended tool for this would be the metal spudger, but not required.
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. Disconnect ribbon tabs 1,2,5,8G, and 3. Remove ribbon tab by pulling gently along motherboard. Do not pull straight out. Then remove the plugs
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. With the Phillips #00 screwdriver, remove the two Phillips screws. With the Phillips #00 screwdriver, remove the two Phillips screws.
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
Conclusione
2 Commenti
Do you know here can i buy a main board for phantom 4 advanced remote controller?
carl_darklife - Replica
I would like to know too, can’t find one anywhere
Luke James -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,275
