Salta al contenuto principale
DJI Phantom 4 Advanced Remote Controller Battery Replacement
Cosa ti serve
  1. DJI Phantom 4 Advanced Remote Controller Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Battery Replacement: passo 2, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Battery Replacement: passo 2, immagine 2 di 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Battery Replacement: passo 3, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Battery Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Battery Replacement: passo 4, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Battery Replacement: passo 4, immagine 2 di 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Battery Replacement: passo 5, immagine 1 di 2 DJI Phantom 4 Advanced Remote Controller Battery Replacement: passo 5, immagine 2 di 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Battery Replacement, Battery: passo 6, immagine 1 di 1
    • The battery is attached to the back plastic, and is towards the bottom of the remote.
    • Unplug the cord that is connected to the bottom of the main board.
  7. DJI Phantom 4 Advanced Remote Controller Battery Replacement: passo 7, immagine 1 di 1
    • After the cord is unplugged, remove the battery by lifting upon the plastic cover, which the battery is attached to.
  8. DJI Phantom 4 Advanced Remote Controller Battery Replacement: passo 8, immagine 1 di 1
    • Once the cover is off you can access the battery.
Conclusione
Altre 10 persone hanno completato questa guida.
4Commenti sulla guida
Grrrrrreat Job!
Rick Artman - Replica
Wo kann ich den Akku bestellen? Danke für die Hilfe!
Xl S - Replica
does someone know where to buy the akku?
Xl S - Replica
Ich habe ein Erzatz Akku eingesetzt mit den gleichen Strom Werten, beim aufladen stelle ich fest das der Akku nicht ladet..
Es blinkt bloß ( schnell) auf einer LED.
Wo kann die Ursache liegen.
Matthias Meier - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 98
Tutti i Tempi: 14,695
