Salta al contenuto principale
DJI Phantom 3 Advanced Landing Gear Replacement
Cosa ti serve
  1. DJI Phantom 3 Advanced Landing Gear Replacement, Battery: passo 1, immagine 1 di 2 DJI Phantom 3 Advanced Landing Gear Replacement, Battery: passo 1, immagine 2 di 2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Landing Gear Replacement: passo 2, immagine 1 di 2 DJI Phantom 3 Advanced Landing Gear Replacement: passo 2, immagine 2 di 2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: passo 3, immagine 1 di 3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: passo 3, immagine 2 di 3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: passo 3, immagine 3 di 3
    • Turn the phantom upside down.
    • Remove the eight 7.5mm long 3mm screws, securing the landing gear to the body of the quadcopter, with a T-8 screwdriver.
  4. DJI Phantom 3 Advanced Landing Gear Replacement: passo 4, immagine 1 di 3 DJI Phantom 3 Advanced Landing Gear Replacement: passo 4, immagine 2 di 3 DJI Phantom 3 Advanced Landing Gear Replacement: passo 4, immagine 3 di 3
    • Remove the rubber spacer in the landing gear by pushing the spacer out of the slot with your finger.
  5. DJI Phantom 3 Advanced Landing Gear Replacement: passo 5, immagine 1 di 3 DJI Phantom 3 Advanced Landing Gear Replacement: passo 5, immagine 2 di 3 DJI Phantom 3 Advanced Landing Gear Replacement: passo 5, immagine 3 di 3
    • Using a plastic opening tool, carefully separate the two pieces of plastic of the landing gear.
    • Be careful not to break the wire attached, as this is your receiver antenna.
  6. DJI Phantom 3 Advanced Landing Gear Replacement: passo 6, immagine 1 di 3 DJI Phantom 3 Advanced Landing Gear Replacement: passo 6, immagine 2 di 3 DJI Phantom 3 Advanced Landing Gear Replacement: passo 6, immagine 3 di 3
    • Feed the wire and attached plastic through the hole in the landing gear.
Conclusione
Altre 7 persone hanno completato questa guida.
Quinn Tirpak
Membro da: 10/06/16
319 Reputazione
2 Guide realizzate
Cal Poly, Team 10-2, Livingston Fall 2016 Membro di Cal Poly, Team 10-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G2
3 Membri
12 Guide realizzate
Un commento
I have a single coax cable in my landing gear. the gear broke and the wire tore off the connector. How do I fix this?
Art - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,848
