Introduzione
Use this guide to replace an Electronic Speed Controller (ESC) in your DJI Phantom Drone 2 Vision+. The ESC receives power from the central board, and a PWM control signal from the flight controller. There is one ESC for each motor, for a total of four. Removing an ESC requires soldering.
Note: the drone used in this guide probably looks different from yours! It's just a custom paint job, otherwise it's completely stock.
Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
  • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
  • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
Aggiungi Commento
Determine if the propellor is clockwise or counter-clockwise rotating.
  • Determine if the propellor is clockwise or counter-clockwise rotating.
  • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
  • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
Aggiungi Commento
  • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
  • Remove the propellor.
Aggiungi Commento
  • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
Aggiungi Commento
  • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
Aggiungi Commento
  • Gently lift up the top shell case.
  • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
Aggiungi Commento
  • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
  • Pull the GPS connector straight up out of its socket.
  • Lift the top shell case up and remove it from the body of the Phantom.
Aggiungi Commento
  • Desolder all three motor wires.
  • When replacing a motor, be sure to solder the new motor in following the same wire color order as when you removed it.
    • The motor spin direction is dependent on the order of the wires, and may not match this image exactly. If you forgot the order, check the arm directly opposite for reference.
Aggiungi Commento
  • Remove the four 2mm hex motor bolts.
Aggiungi Commento
  • Remove the motor from the motor mount.
Aggiungi Commento
  • Cut the zip-tie securing the signal and power cables.
  • Unplug the ESC signal cable molex connector from the ESC.
Aggiungi Commento
  • Desolder the ESC ground and voltage wires from the mainboard.
  • Be careful not to melt the plastic case bottom shell with your soldering iron or damage any electronic components.
  • You can remove in-the-way cables by unplugging them and moving them aside. This will protect them from the warning above.
    • Be sure to plug these cables back in before reassembling your Phantom 2.
Aggiungi Commento
  • Remove the two ESC securing screws.
  • The clear plastic LED cover will either drop from the underside or need to be loosened with a plastic spudger.
Aggiungi Commento
  • With the ESC no longer secured to the airframe, lift it up and remove it.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
David Hoyt
Membro da: 09/04/2010
3.599 Reputazione
44 Guide realizzate
Cal Poly, Team 25-89, Amido Spring 2010 Membro di Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membri
52 Guide realizzate
Is it a difference between ESC from different versions (1.0, 2.0 and 3.0) of Phantom 2?
jarbas_sjo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 100
Tutti i Tempi: 4,485
