Introduzione
No tools are required to remove the battery from your DJI Phantom 2 Vision+. You should always remove the battery before servicing your Phantom to avoid electric shock or accidentally powering the propellors.
Note: the drone used in this guide probably looks different from yours! It's just a custom paint job, otherwise it's completely stock.
Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
  • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
  • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
David Hoyt
Membro da: 09/04/2010
3.626 Reputazione
43 Guide realizzate
Cal Poly, Team 25-89, Amido Spring 2010 Membro di Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membri
52 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,520
