Salta al contenuto principale
DJI Mavic Pro WiFi Board Replacement
Cosa ti serve
  1. DJI Mavic Pro WiFi Board Replacement, Battery: passo 1, immagine 1 di 3 DJI Mavic Pro WiFi Board Replacement, Battery: passo 1, immagine 2 di 3 DJI Mavic Pro WiFi Board Replacement, Battery: passo 1, immagine 3 di 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro WiFi Board Replacement, Upper Shell: passo 2, immagine 1 di 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro WiFi Board Replacement: passo 3, immagine 1 di 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro WiFi Board Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro WiFi Board Replacement: passo 5, immagine 1 di 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro WiFi Board Replacement: passo 6, immagine 1 di 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro WiFi Board Replacement: passo 7, immagine 1 di 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro WiFi Board Replacement, WiFi Board: passo 8, immagine 1 di 1
    • Remove the lone 4mm Phillips #00 screw holding the WiFi board in place by turning the screwdriver counterclockwise.
  9. DJI Mavic Pro WiFi Board Replacement: passo 9, immagine 1 di 1
    Compra
    • Remove the two gold coaxial connectors by pulling gently at the base with tweezers.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S17-G3, White Fall 2018 Membro di Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Membri
14 Guide realizzate
3 Commenti
Is it possible to remove the wifi card completely and fly the drone without it ?
Quentin V - Replica
Are there any connectivity issues, like new passwords etc?
Chris Stoll - Replica
Mine was removed by the former owner and the coaxial connectors were removed at the same time. I bought a new module that has the coaxial wires and one ribbon cable and now I have to see about removing either the bottom of the drone or one of the boards to gain access to where these connectors go to. Is there another video as to how to do that? Several of the hex screws are stripped to the point where my 5mm hex screwdriver don't remove them. Is there a fix for that (stripped screws)?
Mike Belanger - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 55
Tutti i Tempi: 3,346
