Salta al contenuto principale
DJI Mavic Pro Upper Shell Replacement
Cosa ti serve
  1. DJI Mavic Pro Upper Shell Replacement, Battery: passo 1, immagine 1 di 3 DJI Mavic Pro Upper Shell Replacement, Battery: passo 1, immagine 2 di 3 DJI Mavic Pro Upper Shell Replacement, Battery: passo 1, immagine 3 di 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Upper Shell Replacement, Upper Shell: passo 2, immagine 1 di 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Upper Shell Replacement: passo 3, immagine 1 di 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Upper Shell Replacement: passo 4, immagine 1 di 1
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Upper Shell Replacement: passo 5, immagine 1 di 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro Upper Shell Replacement: passo 6, immagine 1 di 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Upper Shell Replacement: passo 7, immagine 1 di 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S17-G3, White Fall 2018 Membro di Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Membri
14 Guide realizzate
2 Commenti
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Lazaro Hernandez - Replica
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
shaun.cunningham - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 64
Tutti i Tempi: 4,666
