Salta al contenuto principale
DJI Mavic Pro Gimbal/Camera Replacement
Cosa ti serve
  1. DJI Mavic Pro Gimbal/Camera Replacement, Battery: passo 1, immagine 1 di 3 DJI Mavic Pro Gimbal/Camera Replacement, Battery: passo 1, immagine 2 di 3 DJI Mavic Pro Gimbal/Camera Replacement, Battery: passo 1, immagine 3 di 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Gimbal/Camera Replacement, Upper Shell: passo 2, immagine 1 di 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Gimbal/Camera Replacement: passo 3, immagine 1 di 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Gimbal/Camera Replacement: passo 4, immagine 1 di 1
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Gimbal/Camera Replacement: passo 5, immagine 1 di 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro Gimbal/Camera Replacement: passo 6, immagine 1 di 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Gimbal/Camera Replacement: passo 7, immagine 1 di 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro Gimbal/Camera Replacement, Gimbal/Camera: passo 8, immagine 1 di 1
    • Remove the one 5mm JIS #0 screw from the small micro controller board at the front of the DJI Mavic Pro by turning counterclockwise.
  9. DJI Mavic Pro Gimbal/Camera Replacement: passo 9, immagine 1 di 1
    • Pull the cord and micro controller board away from the front of the DJI Mavic Pro using tweezers.
  10. DJI Mavic Pro Gimbal/Camera Replacement: passo 10, immagine 1 di 2 DJI Mavic Pro Gimbal/Camera Replacement: passo 10, immagine 2 di 2
    • Expose the two small ZIF connectors near the front of the board by removing the plastic coverings.
    • Then, remove the two ZIF connectors under the coverings using a nylon spudger.
  11. DJI Mavic Pro Gimbal/Camera Replacement: passo 11, immagine 1 di 1
    • Remove two 6mm JIS #00 screws from the plastic board cover at the front of the DJI Mavic Pro.
  12. DJI Mavic Pro Gimbal/Camera Replacement: passo 12, immagine 1 di 2 DJI Mavic Pro Gimbal/Camera Replacement: passo 12, immagine 2 di 2
    • Flip the DJI Mavic Pro over.
    • Gently press the latch for the Gimbal cover.
    • Pull the cover off.
  13. DJI Mavic Pro Gimbal/Camera Replacement: passo 13, immagine 1 di 2 DJI Mavic Pro Gimbal/Camera Replacement: passo 13, immagine 2 di 2
    • Flip the DJI Mavic Pro back over, with its top side facing up.
    • Remove the two ZIF connectors located behind the plastic covers by using a nylon spudger.
  14. DJI Mavic Pro Gimbal/Camera Replacement: passo 14, immagine 1 di 1
    • Gently remove the power cable connector located to the left, behind the gimbal board, by pulling up on the white base.
  15. DJI Mavic Pro Gimbal/Camera Replacement: passo 15, immagine 1 di 1
    • Scrape away the plastic adhesive covering the two 5mm JIS #000 screws connected to the gimbal board.
    • Remove the two 5mm JIS #000 screws from the gimbal board by turning the screwdriver counterclockwise.
  16. DJI Mavic Pro Gimbal/Camera Replacement: passo 16, immagine 1 di 1
    • Remove the two 7mm JIS #00 screws at the very front of the DJI Mavic Pro by turning the screwdriver counterclockwise.
    • Careful when removing these screws the camera or whatever remains of your camera assembly may drop
  17. DJI Mavic Pro Gimbal/Camera Replacement: passo 17, immagine 1 di 2 DJI Mavic Pro Gimbal/Camera Replacement: passo 17, immagine 2 di 2
    • Flip the DJI Mavic Pro over, with the camera facing you.
    • Gently pull the gimbal/camera assembly up and out.
Conclusione
Altre 48 persone hanno completato questa guida.
Nicole Lai
Membro da: 10/08/18
481 Reputazione
2 Guide realizzate
Cal Poly, Team S17-G3, White Fall 2018 Membro di Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Membri
14 Guide realizzate
12 Commenti
THANK YOU!!!!!! Perfect!
Chris Hunt - Replica
u didn’t tell me to remove to front two screws on the bottom and you made me break the tok off. U guys suck and owe me 20$ for a new top. &&^& u
James - Replica
Didn‘t see Step 5?
Klausi -
bro stfu and open your eyes
Hani Awad -
Bonjour,
Merci pour cette tuto qui m’a permis d’effectuer la manipulation sans problème. Mais il se fait qu’après le changement de tout le cadran de la caméra avec le câble plat (Gimbal) achété sur amazon, tout s’affiche normalement, sauf que l’écran reste noir, aucun retour vidéo et aucune photo enregistrée. J’ai vérifié que toutes les connexions sont bien effectuées.
Pourriez-vous avoir une idée de ce qui peut être la cause?
Merci d’avance
Alain
Alain Lushimba - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 74
Ultimi 30 Giorni: 419
Tutti i Tempi: 40,172
