Salta al contenuto principale
DJI Mavic Mini Propellers Replacement
Cosa ti serve
  1. DJI Mavic Mini Propellers Replacement, Propellers: passo 1, immagine 1 di 3 DJI Mavic Mini Propellers Replacement, Propellers: passo 1, immagine 2 di 3 DJI Mavic Mini Propellers Replacement, Propellers: passo 1, immagine 3 di 3
    • Place the DJI Mavic Mini on a flat surface with the props oriented upwards.
    • For ease of access place the prop arms in the "open" position.
  2. DJI Mavic Mini Propellers Replacement: passo 2, immagine 1 di 3 DJI Mavic Mini Propellers Replacement: passo 2, immagine 2 di 3 DJI Mavic Mini Propellers Replacement: passo 2, immagine 3 di 3
    • Remove the 2.4 mm J000 screw from the damaged propeller.
    • When removing the screws, you may need to apply some pressure to the swivel mount that holds the propellers.
    • Remove the damaged propellers.
  3. DJI Mavic Mini Propellers Replacement: passo 3, immagine 1 di 2 DJI Mavic Mini Propellers Replacement: passo 3, immagine 2 di 2
    • Keep the 2.4 mm J000 screw from the damaged propeller to use again when fastening on the replacement.
    • While one or both propellers are removed for replacement, it is recommended that you inspect the exposed swivel mount for any debris which may impact drone performance.
    • Additionally, when fastening the replacement propeller make sure that the screw is inserted into the interior hole on the swivel mount.
Conclusione
Chase Smith
Membro da: 02/22/22
147 Reputazione
1 Guida realizzata
Clemson, Team 1-2, Hunter Spring 2022 Membro di Clemson, Team 1-2, Hunter Spring 2022
CLEM-HUNTER-S22S1G2
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 873
