Introduzione
Is your DJI Mavic Mini experiencing difficulty maintaining a charge, throwing “Max Force/ESC” errors, or periodically disconnecting? Many of these problems can be result from an obstructed or faulty battery module, in addition to a few other conditions. In this guide, we will outline how to determine if a battery module is the likely source of these issues, and if it is, we will detail the removal, inspection, and replacement of a battery module for the DJI Mavic Mini.
Orient the DJI Mavic Mini so that the camera faces away.
Use your finger to depress the lip on the panel until the lid becomes ajar.
Flip the panel up to expose the battery module.
Is your DJI Mavic Mini experiencing trouble with positioning, stability, or returning to home? Many of these problems an be due to weak signals or a faulty GPS. In this set of instructions, we will detail the removal process, inspection, and replacement of the DJI Mavic Mini GPS Module.
