Introduzione
Credit for images and text goes to our partner, Bondtech AB
Use 2x 2.5x6mm screws supplied with the Copperhead™ hotend.
Insert them in the mounting holes.
Attach Adapter and hotend.
New lineNotice the orientation of the Adapter and Hot Block.
These indented marks should be oriented towards the front of the DDX.
The fixation screws that attach the DDX to the carriage plate will enter through them.
Insert the Capricorn tube inside the Adapter and hotend.
Push hard until it hits the bottom.
Insert the Capricorn tube in the cutting fixture
Drive it until it fits the Adapter
Pressing all together use the hobby knife to cut the tube straight.
At the end, the Capricorn should stand out about 5mm.
Spread the housing apart from 2 to 3mm
Insert the Copperhead™ in at an angle.
Push it until the mounting holes align.
If when clamping the DDX the gears collide:
Release the thumbscrew.
Open the hinge.
Clamp both halves while rotating the main gear back and forth.
When the DDX closes down verify the mounting holes alignment.
Screw the back screws to close it.
2Commenti sulla guida
where do i get the cutting fixture
Thanks for your questions. We’ve added a link to step 3.
