Salta al contenuto principale
DBPOWER T20 Fan Replacement
Cosa ti serve
  1. DBPOWER T20 Fan Replacement, DBPOWER T20 Disassembly: passo 1, immagine 1 di 1
    • Flip the device and lay flat.
  2. DBPOWER T20 Fan Replacement: passo 2, immagine 1 di 1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Fan Replacement: passo 3, immagine 1 di 3 DBPOWER T20 Fan Replacement: passo 3, immagine 2 di 3 DBPOWER T20 Fan Replacement: passo 3, immagine 3 di 3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Fan Replacement: passo 4, immagine 1 di 1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Fan Replacement: passo 5, immagine 1 di 2 DBPOWER T20 Fan Replacement: passo 5, immagine 2 di 2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Fan Replacement: passo 6, immagine 1 di 3 DBPOWER T20 Fan Replacement: passo 6, immagine 2 di 3 DBPOWER T20 Fan Replacement: passo 6, immagine 3 di 3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Fan Replacement: passo 7, immagine 1 di 2 DBPOWER T20 Fan Replacement: passo 7, immagine 2 di 2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Fan Replacement: passo 8, immagine 1 di 1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Fan Replacement: passo 9, immagine 1 di 2 DBPOWER T20 Fan Replacement: passo 9, immagine 2 di 2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Fan Replacement: passo 10, immagine 1 di 2 DBPOWER T20 Fan Replacement: passo 10, immagine 2 di 2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Fan Replacement, Fan: passo 11, immagine 1 di 2 DBPOWER T20 Fan Replacement, Fan: passo 11, immagine 2 di 2
    • Pull the fan up and out of the housing.
    • In this image the lamp and power input have been removed to increase visibility, you do not have to remove these to remove the fan.
Conclusione
Altre 7 persone hanno completato questa guida.
2 Commenti
Any idea of the specifications of the fan? 12v, 24v? I want to change it for another more quiet… but not sure about its voltage. It is 50x50x20mm right? Thanks!
Agustín Castiñeira Fernández - Replica
Hola! También querria sustituirlo por otro más silencioso. ¿Alguna idea de sus especificaciones?
Joan Abrines - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,130
