Salta al contenuto principale
D-Link HD Wi-Fi Camera Light Sensor Replacement
Cosa ti serve
  1. D-Link HD Wi-Fi Camera Light Sensor Replacement, Motherboard: passo 1, immagine 1 di 1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera Light Sensor Replacement: passo 2, immagine 1 di 2 D-Link HD Wi-Fi Camera Light Sensor Replacement: passo 2, immagine 2 di 2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link HD Wi-Fi Camera Light Sensor Replacement: passo 3, immagine 1 di 2 D-Link HD Wi-Fi Camera Light Sensor Replacement: passo 3, immagine 2 di 2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera Light Sensor Replacement, Microphone: passo 4, immagine 1 di 1
    • To remove the front cover, place index finger in the center and pull away from the frame. This may take a little effort, but should not require an opening tool.
  5. D-Link HD Wi-Fi Camera Light Sensor Replacement: passo 5, immagine 1 di 2 D-Link HD Wi-Fi Camera Light Sensor Replacement: passo 5, immagine 2 di 2
    • After the cover is removed, unscrew the two Phillips #00 5.0mm screws. Then the board should slide right out.
  6. D-Link HD Wi-Fi Camera Light Sensor Replacement, Light Sensor: passo 6, immagine 1 di 1
    • The light sensor is located at the bottom of the board.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,786
