Salta al contenuto principale
D-Link EBR-2310 LED Light Replacement
Cosa ti serve
  1. D-Link EBR-2310 LED Light Replacement, Remove Plastic Screw Coverings: passo 1, immagine 1 di 1
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
  2. D-Link EBR-2310 LED Light Replacement, Remove Screws: passo 2, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the two top screws.
  3. D-Link EBR-2310 LED Light Replacement, Pry Open The Router: passo 3, immagine 1 di 1
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
  4. D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: passo 4, immagine 1 di 2 D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: passo 4, immagine 2 di 2
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
  5. D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: passo 5, immagine 1 di 2 D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: passo 5, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
  6. D-Link EBR-2310 LED Light Replacement, Remove Bottom Case: passo 6, immagine 1 di 1
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
  7. D-Link EBR-2310 LED Light Replacement, Locate Problematic LED light: passo 7, immagine 1 di 1
    • Locate the problematic LED light on the motherboard.
    • Using a plastic opening tool, very gently tilt its black base backwards.
  8. D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: passo 8, immagine 1 di 2 D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: passo 8, immagine 2 di 2
    • Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
  9. D-Link EBR-2310 LED Light Replacement, Remove the LED Light: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
  10. D-Link EBR-2310 LED Light Replacement, Complete Removal: passo 10, immagine 1 di 1
    • You should now have a removed LED light, ready to be replaced with a new one.
Conclusione
Jessica
Membro da: 09/19/14
428 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 391
