Salta al contenuto principale
D-Link DCS-5222L WiFi Antenna Replacement
Cosa ti serve
  1. D-Link DCS-5222L WiFi Antenna Replacement, WiFi Antenna: passo 1, immagine 1 di 3 D-Link DCS-5222L WiFi Antenna Replacement, WiFi Antenna: passo 1, immagine 2 di 3 D-Link DCS-5222L WiFi Antenna Replacement, WiFi Antenna: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Locate and remove the four rubber feet on the bottom of the camera using your fingers or a pair of tweezers.
  2. D-Link DCS-5222L WiFi Antenna Replacement: passo 2, immagine 1 di 2 D-Link DCS-5222L WiFi Antenna Replacement: passo 2, immagine 2 di 2
    • Using a #1 Phillips screwdriver, remove the four 7mm screws that are exposed by the removed feet.
  3. D-Link DCS-5222L WiFi Antenna Replacement: passo 3, immagine 1 di 2 D-Link DCS-5222L WiFi Antenna Replacement: passo 3, immagine 2 di 2
    • Using your hands, open the camera body by wiggling the bottom free from the upper shell.
    • Open the shell carefully, as the motherboard is attached to the bottom of the body; all of the components in the upper body are accordingly connected to the bottom. Likewise, the WiFi antenna is mounted to the upper shell, but a wire connects it to the motherboard on the bottom of the body.
  4. D-Link DCS-5222L WiFi Antenna Replacement: passo 4, immagine 1 di 2 D-Link DCS-5222L WiFi Antenna Replacement: passo 4, immagine 2 di 2
    • Using your soldering iron, heat the antenna contacts on the motherboard until the wire releases.
    • Soldering Irons are hot and can burn you and ignite flammable materials.
  5. D-Link DCS-5222L WiFi Antenna Replacement: passo 5, immagine 1 di 2 D-Link DCS-5222L WiFi Antenna Replacement: passo 5, immagine 2 di 2
    • Pinch the WiFi antenna's clip mount inside the upper part of the body with blunt ended tweezers while pulling the antenna from the outside.
Conclusione
Ryan Null
Membro da: 10/26/18
377 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,171
