Salta al contenuto principale
D-Link DCS-5222L Speaker Replacement
Cosa ti serve
  1. D-Link DCS-5222L Speaker Replacement, Speaker: passo 1, immagine 1 di 3 D-Link DCS-5222L Speaker Replacement, Speaker: passo 1, immagine 2 di 3 D-Link DCS-5222L Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Remove the four rubber pieces to gain access to the screws.
    • Remove the four 7mm screws with a #1 Phillips screwdriver.
    • Remove the bottom of the camera body.
  2. D-Link DCS-5222L Speaker Replacement: passo 2, immagine 1 di 2 D-Link DCS-5222L Speaker Replacement: passo 2, immagine 2 di 2
    • Using safety tweezers, disconnect the 2-wire connector with the red and black leads located close to the ethernet and SD ports.
    • Disconnect the cables gently.
  3. D-Link DCS-5222L Speaker Replacement: passo 3, immagine 1 di 2 D-Link DCS-5222L Speaker Replacement: passo 3, immagine 2 di 2
    • The speaker is circular, black and silver in color with a red and black cord. It is easily removed from the upper body of the camera with your fingers or safety tweezers.
Conclusione
Jason Munyon
Membro da: 10/30/18
268 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 305
