Salta al contenuto principale
D-Link DCS-5222L Lens Replacement
Cosa ti serve
  1. D-Link DCS-5222L Lens Replacement, Lens: passo 1, immagine 1 di 3 D-Link DCS-5222L Lens Replacement, Lens: passo 1, immagine 2 di 3 D-Link DCS-5222L Lens Replacement, Lens: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the four rubber feet with tweezers to access the screws.
    • Remove all four 7mm screws by using a #1 Phillips screwdriver.
    • Then, with your hands, pull off the lower part of the camera body.
  2. D-Link DCS-5222L Lens Replacement: passo 2, immagine 1 di 3 D-Link DCS-5222L Lens Replacement: passo 2, immagine 2 di 3 D-Link DCS-5222L Lens Replacement: passo 2, immagine 3 di 3
    • On the base motherboard, there are five connecting cables. Disconnect all of them from the motherboard gently using safety tweezers.
    • Do not cut or damage the cables.
    • Disconnecting the antenna cable from motherboard is not necessary.
  3. D-Link DCS-5222L Lens Replacement: passo 3, immagine 1 di 3 D-Link DCS-5222L Lens Replacement: passo 3, immagine 2 di 3 D-Link DCS-5222L Lens Replacement: passo 3, immagine 3 di 3
    • Remove the two 7mm screws holding the motor using a #1 Phillips screwdriver.
    • Pull off the motor and lift away the midbody of the camera using your hands.
  4. D-Link DCS-5222L Lens Replacement: passo 4, immagine 1 di 2 D-Link DCS-5222L Lens Replacement: passo 4, immagine 2 di 2
    • Separate the black camera shroud from the upper body by prying loose the tabs with a plastic opening tool or spudger.
    • Use your hands to wiggle the shroud free.
  5. D-Link DCS-5222L Lens Replacement: passo 5, immagine 1 di 3 D-Link DCS-5222L Lens Replacement: passo 5, immagine 2 di 3 D-Link DCS-5222L Lens Replacement: passo 5, immagine 3 di 3
    • Use a #1 Phillips screwdriver to unscrew the four 5mm screws on both sides of the black camera housing to separate it from white body.
    • Unscrew the two 7mm #1 Phillips screws on both sides of the camera housing to open it.
  6. D-Link DCS-5222L Lens Replacement: passo 6, immagine 1 di 3 D-Link DCS-5222L Lens Replacement: passo 6, immagine 2 di 3 D-Link DCS-5222L Lens Replacement: passo 6, immagine 3 di 3
    • Gently disconnect the three cables from the small motherboard using safety tweezers.
    • Use a #0 Phillips screwdriver to remove the two black 2mm screws and a #1 Phillips screwdriver to remove the 2 silver 6mm screws.
    • Separate the board from the black housing.
  7. D-Link DCS-5222L Lens Replacement: passo 7, immagine 1 di 3 D-Link DCS-5222L Lens Replacement: passo 7, immagine 2 di 3 D-Link DCS-5222L Lens Replacement: passo 7, immagine 3 di 3
    • Using your fingers, remove the focus adjustment ring.
    • Twist the lens to unscrew it from the camera module.
    • Replace the broken lens with new one and reassemble all parts of the camera respectively.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 979
