Salta al contenuto principale
D-Link DCS-2630L Wi-Fi Camera Speaker Replacement
Cosa ti serve
  1. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement, Back casing: passo 1, immagine 1 di 1
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the back casing to expose the circuit board.
  3. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: passo 3, immagine 1 di 1
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  4. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: passo 4, immagine 1 di 1
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  5. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • Remove the two 7.25 mm screws using the Ph00 head.
  6. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the back grey speaker plate
  7. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: passo 7, immagine 1 di 1
    • Remove the speaker by gently pulling on the wire near the speaker.
Conclusione
Collyn Dodge
Membro da: 03/21/18
323 Reputazione
2 Guide realizzate
IUPUI, Team S4-G2, Baechle Spring 2018 Membro di IUPUI, Team S4-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 258
