Salta al contenuto principale
D-Link DCS-2630L Wi-Fi Camera Microphone Replacement
Cosa ti serve
  1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Back casing: passo 1, immagine 1 di 1
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 2, immagine 1 di 1
    • Remove the back casing to expose the circuit board.
  3. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 3, immagine 1 di 1
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  4. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 4, immagine 1 di 1
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  5. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Microphone: passo 5, immagine 1 di 1
    • Remove the two 4.35 mm screws on the circuit board using the Philips head PH00 screw driver.
  6. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 6, immagine 1 di 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 6, immagine 2 di 2
    • Detach the white plug by gently pulling on the black wires.
  7. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 7, immagine 1 di 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 7, immagine 2 di 2
    • Remove the circuit board to expose the camera body.
    • At the same time, you will need to feed the wires through the circuit board and out the slot in the black plate under the circuit board.
  8. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 8, immagine 1 di 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 8, immagine 2 di 2
    • Gently pull on the grey wire to detach the microphone from the camera body.
  9. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 9, immagine 1 di 3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 9, immagine 2 di 3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 9, immagine 3 di 3
    • Detach the microphone from the circuit board by gently pulling on the grey wire.
Conclusione
IUPUI, Team S4-G2, Baechle Spring 2018 Membro di IUPUI, Team S4-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 369
