Salta al contenuto principale
D-Link HD Wi-Fi Camera Motherboard Replacement
Cosa ti serve
  1. D-Link   HD Wi-Fi Camera Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link   HD Wi-Fi Camera Motherboard Replacement: passo 2, immagine 1 di 2 D-Link   HD Wi-Fi Camera Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link   HD Wi-Fi Camera Motherboard Replacement: passo 3, immagine 1 di 2 D-Link   HD Wi-Fi Camera Motherboard Replacement: passo 3, immagine 2 di 2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
Conclusione
1Commento della guida
Where can I get the replacement motherboard? Been trying to search online, but to no avail.
Azlin Rahim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,039
