Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Use this guide to assist with general disassembly or troubleshooting of your braille display.
Parti
Nessuna parte specificata.
  1. Remove the four bottom screws with a Phillips #00 screwdriver. Remove the four bottom screws with a Phillips #00 screwdriver.
    • Remove the four bottom screws with a Phillips #00 screwdriver.
  2. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset.
    • Remove the plastic cover, paper and chipset.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove the two screws with a Phillips #00 screwdriver on the logic board. take out the main circuit like show in the picture take out the main circuit like show in the picture
    • Remove the two screws with a Phillips #00 screwdriver on the logic board.
    • take out the main circuit like show in the picture
  5. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver.
    • Remove the four screws with a Phillips #00 screwdriver.
  6. Remove the connector delicately. Remove the connector delicately. Remove the connector delicately.
    • Remove the connector delicately.
  7. when you put it back together make sure mechanical cells are connected correctly when you put it back together make sure mechanical cells are connected correctly
    • when you put it back together make sure mechanical cells are connected correctly
Conclusione
Sisyphe
Membro da: 29/07/2013
332 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 622
