Salta al contenuto principale
Cyberpower Elite M1-131 Cord Replacement
Cosa ti serve
  1. Cyberpower Elite M1-131 Cord Replacement, Cord: passo 1, immagine 1 di 3 Cyberpower Elite M1-131 Cord Replacement, Cord: passo 1, immagine 2 di 3 Cyberpower Elite M1-131 Cord Replacement, Cord: passo 1, immagine 3 di 3
    • Hold the mouse in a position where the feet are facing you.
    • With a plastic anti-static tweezer or a Spudger, take off the mouse feet carefully.
    • The feet will need to be reapplied during reassembly.
  2. Cyberpower Elite M1-131 Cord Replacement: passo 2, immagine 1 di 2 Cyberpower Elite M1-131 Cord Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws on the back.
    • Do not remove the white part on the mouse feet. They are sticky and will help put your mouse feet back on.
  3. Cyberpower Elite M1-131 Cord Replacement: passo 3, immagine 1 di 3 Cyberpower Elite M1-131 Cord Replacement: passo 3, immagine 2 di 3 Cyberpower Elite M1-131 Cord Replacement: passo 3, immagine 3 di 3
    • Gently put the mouse down with the sensor facing down and carefully pull the top shell from the mouse.
  4. Cyberpower Elite M1-131 Cord Replacement: passo 4, immagine 1 di 3 Cyberpower Elite M1-131 Cord Replacement: passo 4, immagine 2 di 3 Cyberpower Elite M1-131 Cord Replacement: passo 4, immagine 3 di 3
    • Grasp the 5-pin plastic white pin connector from both sides and gently pull it up.
    • Do NOT pull on the wires.
  5. Cyberpower Elite M1-131 Cord Replacement: passo 5, immagine 1 di 2 Cyberpower Elite M1-131 Cord Replacement: passo 5, immagine 2 di 2
    • Unwrap the old cable, pull it out, and remove it from sight.
  6. Cyberpower Elite M1-131 Cord Replacement: passo 6, immagine 1 di 3 Cyberpower Elite M1-131 Cord Replacement: passo 6, immagine 2 di 3 Cyberpower Elite M1-131 Cord Replacement: passo 6, immagine 3 di 3
    • With your new cable, place the 5-pin connector into the connector socket.
    • Do NOT push down on the wires.
    • Tuck in the cable.
    • Place the plastic cube in front of the mouse wheel. There will be a perfect fit for that cube to hold the cable in place.
  7. Cyberpower Elite M1-131 Cord Replacement: passo 7, immagine 1 di 2 Cyberpower Elite M1-131 Cord Replacement: passo 7, immagine 2 di 2
    • Place the top shell back on top of the mouse and press down until you hear a small click.
    • Lift the mouse so the sensor is facing you.
  8. Cyberpower Elite M1-131 Cord Replacement: passo 8, immagine 1 di 2 Cyberpower Elite M1-131 Cord Replacement: passo 8, immagine 2 di 2
    • Screw back in the four 2 mm screws that you removed earlier with your Phillips screwdriver.
  9. Cyberpower Elite M1-131 Cord Replacement: passo 9, immagine 1 di 2 Cyberpower Elite M1-131 Cord Replacement: passo 9, immagine 2 di 2
    • Reapply the mouse feet that you carefully took off earlier.
    • You can also apply new ones if you have any.
Conclusione
1Commento della guida
This was really helpful as I initially put the pins in backward and needed to see the default pin-out and Googling landed me here. I took each pin out of the header individually with a safety pin and I ended up using a cord from a corsair strafe mouse, "gonna really confuse someone one day seeing those mismatched parts". I also recommend to put two tiny dabs of super glue on the two nubs that plug in the plastic assembly for those two buttons below the wheel because as-is its just a friction fit and they push in and fall inside the mouse, and also to use a tiny bit of the super glue to re-apply the plastic over the screws because that adhesive sticky tape just won't hold after pulling them up.
Joshua Pierre - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 74
Tutti i Tempi: 1,722
